Stainless Steel
Sheet Metal tolerances and specifications
Standard Tolerances For Stainless Steel
304 Stainless Steel (A240 TP304 2B)
| Stainless Steel | Specified Thickness | Tolerance |
| 11 Gauge | 0.120" | 3.05 mm | ± 0.005" | 0.13mm |
| 12 Gauge | 0.109” | 2.78mm | ± 0.009" | 0.23mm |
| 14 Gauge | 0.078” | 1.98mm | ± 0.007" | 0.18mm |
| 16 Gauge | 0.063” | 1.59mm | ± 0.006" | 0.15mm |
| 18 Gauge | 0.050” | 1.27mm | ± 0.005" | 0.13mm |
| 20 Gauge | 0.038” | 0.95mm | ± 0.004" | 0.10mm |
| 22 Gauge | 0.031" | 0.79 mm | ± 0.004" | 0.10mm |
| 24 Gauge | 0.025" | 0.64 mm | ± 0.003" | 0.08mm |
