Aluminum Bar Stock
Bar Stock (CNC Machining) tolerances and specifications
Fabrication Tolerances for Dimensional Variance in Aluminum Bar Stock and Machined Parts
Stocked Aluminum FLAT Bar Stock
| Specified Thickness | Alloy | Tolerance |
| 1/2" x 3/4" | 12.70mm x 19.05mm | 6061-T6 | ± 0.024" | 0.61mm |
| 1/2" x 1" | 12.70mm x 25.4mm | 6061-T6 | ± 0.012" | 0.30mm |
| 1/2" x 2" | 12.70mm x 50.80mm | 6061-T6 | ± 0.024" | 0.61mm |
| 1/2" x 4" | 12.70mm x 101.60mm | 6061-T6 | ± 0.034" | 0.86mm |
| 3/4" x 3/4" | 19.05mm x 19.05mm | 6061-T6 | ± 0.010" | 0.25mm |
| 3/4" x 2" | 19.05mm x 50.80mm | 6061-T6 | ± 0.024" | 0.61mm |
| 3/4" x 4" | 19.05mm x 101.60mm | 6061-T6 | ± 0.034" | 0.86mm |
| 1-1/2" x 2" | 38.10mm x 50.80mm | 6061-T6 | ± 0.024" | 0.61mm |
| 1-1/2" x 3" | 38.10mm x 76.20mm | 6061-T6 | ± 0.024" | 0.61mm |
| 1" x 2" | 25.40mm x 50.80mm | 6061-T6511 | ± 0.024" | 0.61mm |
| 1" x 4" | 25.40mm x 101.60mm | 6061-T6511 | ± 0.034" | 0.86mm |
| 1" x 6" | 25.40mm x 152.40mm | 6061-T6 | ± 0.044" | 1.18mm |
| 2" x 2" | 50.80mm x 50.80mm | 6061-T6511 | ± 0.024" | 0.61mm |
| 2" x 3" | 50.80mm x 76.20mm | 6061-T6511 | ± 0.024" | 0.61mm |
| 3" x 3" | 76.20mm x 76.20mm | 6061-T6 | ± 0.034" | 0.86mm |
Stocked Aluminum ROUND Bar Stock
| 1" | 25.4mm | 6061-T6 | ± 0.012" | 0.30mm |
| 1.5" | 38.1mm | 6061-T6 | ± 0.014" | 0.36mm |
| 2" | 50.8mm | 6061-T6 | ± 0.024" | 0.61mm |
| 2.5" | 63.5mm | 6061-T6 | ± 0.024" | 0.61mm |
| 3" | 76.2mm | 6061-T6 | ± 0.024" | 0.61mm |
| 4" | 101.6mm | 6061-T6 | ± 0.034" | 0.86mm |
| 6" | 152.4mm | 6061-T6 | ± 0.044" | 1.18mm |
