Aluminum Extrusion
Extrusions & Structural tolerances and specifications
Standard Tolerances For Aluminum Extrusion
Stocked Aluminum 6063 Extrusion
| Height | Tolerance (Height) | Tolerance (Width) |
| 1U (Height: 1.72" | 43.688 mm) | ± 0.014" | 0.36mm | ± 0.010" | 0.25mm |
| 2U (Height: 3.47" | 88.138 mm) | ± 0.024" | 0.61mm | ± 0.010" | 0.25mm |
