Cold Rolled Steel Bar Stock
Bar Stock (CNC Machining) tolerances and specifications
Fabrication Tolerances for Dimensional Variance in Steel Bar Stock and Machined Parts
Standard Tolerances For Cold Rolled Steel Bar Stock
Stocked Cold Rolled Steel ROUND Bar Stock
| Specified Thickness | Alloy | Tolerance |
| 1" | 25.4mm | Grade 1018 | ± 0.002" | 0.051mm |
| 2" | 50.8mm | Grade 1018 | ± 0.003" | 0.08mm |
