Aluminum Angle
Extrusions & Structural tolerances and specifications
Fabrication Tolerances for Dimensional Variance in Aluminum Angle and Machined Parts
Standard Tolerances For Structural Aluminum Angle
Stocked Aluminum Alloy (Angle)
| Specified Thickness | Alloy | Tolerance |
| 1" | 25.4mm | TP304 | ± 0.025" | 0.64mm |
| 2" | 50.8mm | TP304 | ± 0.030" | 0.76mm |
