resource bends diagram Protocase Resources
The information below is intended to be helpful for customers who wish to learn more about enclosure design. Also, please use our online support if you have questions for our expert design staff.
Standard Tolerances For Stainless Steel
Usually, choosing material thickness is one of the first steps a designer takes when starting a project. We work with nominal thicknesses, so it's important to know the thickness tolerance on the material you chose, in order to know if the final product will be suitable for your application. It's also important when working with sheet metal that you factor in finish tolerances. For example, if you add a finish such as powdercoat, you add more thickness - this should be factored into your design at the beginning.
304 Stainless Steel (A240 TP304 2B)
Stainless Steel Specified Thickness Tolerance
11 Gauge 0.120" | 3.05 mm ± 0.005" | 0.13mm
12 Gauge 0.109” | 2.78mm ± 0.009" | 0.23mm
14 Gauge 0.078” | 1.98mm ± 0.007" | 0.18mm
16 Gauge 0.063” | 1.59mm ± 0.006" | 0.15mm
18 Gauge 0.050” | 1.27mm ± 0.005" | 0.13mm
20 Gauge 0.038” | 0.95mm ± 0.004" | 0.10mm
22 Gauge 0.031" | 0.79 mm ± 0.004" | 0.10mm
24 Gauge 0.025" | 0.64 mm ± 0.003" | 0.08mm
