Standard Tolerances For Perforated Sheet Metal
Usually, choosing material thickness is one of the first steps a designer takes when starting a project. We work with nominal thicknesses, so it's important to know the thickness tolerance on the material you chose, in order to know if the final product will be suitable for your application. It's also important when working with sheet metal that you factor in finish tolerances. For example, if you add a finish such as powdercoat, you add more thickness - this should be factored into your design at the beginning.
Perforated metal is any type of sheet metal that has a pattern of holes punched into it. This makes it useful for controlling the passage of air, light, liquids, and even sound. Perforated sheet metal is most commonly used for ventilation and filtering.
Stocked Perforated Sheet Metal
Aluminum | Specified Thickness | Tolerance |
20 Gauge | 0.032" | 0.81 mm | ± 0.0030" | 0.08mm |
Cold Rolled Steel | Specified Thickness | Tolerance |
22 Gauge | 0.030" | 0.76 mm | ± 0.0030" | 0.08mm |
