The maximum size of machined parts we are able to engrave in a single setup is 26" x 16" (660.40mm x 406.40mm).
The depth of Protocase's machined engraving is standard, set at 0.010" (0.25mm).
Our standard machined engraving depth can vary depending on the material used, as well as any secondary finish applied post engraving. For example, stainless steel and cold-rolled steel's stiffness will produce a shallower depth compared to aluminum, which is a more lightweight material.
Maximum font size is only limited to the size constraints of our milling machine (see above). For ideal legibility, we recommend using a font with a size no lower than 10pt.
We offer machined engraving on a variety of finishes:
*Anodizing is an electrochemical process that converts the metal surface (aluminum, typically) into a decorative, durable, corrosion-resistant, anodic oxide finish. Although anodizing is a finish we offer, it is performed externally. As a result, our standard lead time does not apply - turnaround times are typically 1-2 weeks.
Please contact our sales team for more information.
Machined Engraving is a permanent part marking method which is recommended for applications requiring MIL-STD-130 (Table II).
