Laser marking offers several different kinds of marking, with each achieving a specific aesthetic and texture. Depending on your requirements, you may employ more than one type of laser marking within your custom enclosures, parts and panels.
Engrave
This type of mark is created by removing material to create a mark that has depth, with the end result of an embossed look. The engraving depth can vary from minimal to extreme, depending on the time allowed for the marking process. If choosing engraving, please specify to your Protocase Account Manager the ideal level of depth for your engraving.
Burn
This type of mark is created by aggressively burning the surface of the material. Depending on the substrate, the mark will vary in color from medium brown to black and black-grey. Post burn, the material's surface will feel rough to the touch and feature areas of rise and fall.
Silver
This type of mark is created by frosting the surface of the material at high speeds, which will result in a bright or white-colored marking. The end resulting mark may have a slight texture to the touch, but the surface or coating penetration is minimal, if at all.
Outline
This type of mark is a simple line etch of the profile, with very little depth. To the touch, the outline mark will be very minimal.
Ablate
This type of mark is created by removing the surface coated layer of a material, whether powdercoat or anodizing. This usually results in a bright or white-colored mark when contrasted with the coating. For this reason, ablate laser marking is aesthetically strongest when it is contrasted with a darker color (such as black, blue, red, etc). Once completed, the mark is relatively smooth with minimal surface penetration.
Anneal
Available only on stainless steel, this type of mark is created by applying a large amount of heat to the stainless steel while minimizing the aggressiveness of the mark. The end result is a solid mark with a surface finish that is smooth.
Anneal is available in five different colors:
Anneal (Default Option)
Anneal Black
Anneal Blue-Silver
Anneal Sunset-Gold
Anneal Green
NOTE: Colors may alter if there is a large amount of text or graphics being laser marked, as there will be additional heat. For example, laser marking in Anneal Green may turn slightly gold.
Laser marking in Engrave, Burn, Silver, Outline and Ablate is available on sheet metal and CNC machined aluminum panels, parts and enclosures, so long as the material thickness is 0.051" or greater.
Laser marking in the Anneal category is exclusively available for sheet metal and CNC machined stainless steel panels, parts and enclosures, so long as the material thickness is 0.051" or greater.
If you require laser marking on materials other than aluminum or stainless steel, contact us to discuss your needs.
We offer laser marking on a variety of finishes:
| Specification | Value |
| Maximum Part Size | 28" x 31" x 12.46" (711.2mm x 787.4mm x 316.4mm) |
| Maximum Mark-able Footprint | 23.62" x 23.62" (599.44mm x 599.44mm) |
| Maximum Height of Face Being Engraved | 12.46" (316.4mm) |
In order to achieve legible and clear laser marking, the minimum font size for all types of laser marking is 4pt font (0.056" | 1.42mm).
Please contact us for more information.
Laser Marking is a permanent part marking method which is recommended for applications requiring MIL-STD-130 (Table II).
