NOTE: The last three examples show dot peening under powder coat.
The maximum area of each marking window for text is X=1.875" (48mm) (x) Y=1" (25.4mm)
NOTE: The text CANNOT be rotated to create a window that is X=1" (25.4mm) (x) Y=1.875" (48mm). However, customers can request smaller X and Y values for their text window - please inform our sales team if this is the case.
Positional tolerance of text is +/-0.125" (3.18mm) on x and y. Tighter tolerances are possible, but you should contact our technical support should this be necessary.
When requesting Dot Peen Marking on aluminum material thinner than 0.051" (1.30mm), ghosting or witness marks may appear on the reverse side of the print area. However, this is not an issue with other material (i.e: Cold Rolled and Stainless Steel) above 0.048" (1.22mm).
We have the capability to add incremental serial numbers as part of a marking.
When placing an order with dot peening required, ensure you provide us with:
Our system contains 5 different fonts with 2 dot pitches and variable text heights. We currently offer five font types: Varidot (default font), Varidot OCR, 5x7 Dot, 7x9 Dot, and 5x9 Dot OCR. Our standard text heights are between 0.075" (1.86mm) to 0.150" (3.52mm). The following are maximum lines and characters varying by our standard text heights:
| Text Heights | 0.150" (3.52mm) | 0.125" (3.10mm) | 0.100" (2.48mm) | 0.075" (1.86mm) |
| Lines of Text | 5 | 6 | 8 | 8 |
| Characters / Line | 14 (13 for 7x9 Dot) | 16 | 20 | 26 (25 for 7x9 Dot) |
| Characters / Window | 70 | 96 | 160 | 208 |
Lower case text is available but may be obscured under powder coat; testing will be required.
Please contact our sales team if you require non-standard text heights, as testing will be required.
Dot Peening is a permanent part marking method which is recommended for applications requiring MIL-STD-130 (Table II).
