Lead Times:
2-3 business days*
CNC Milling
CNC Machining Work Envelope
In order to machine effectively, and ensure your order is processed as quickly as possible, we recommend familiarizing yourself with our work envelope.
The largest item we can mill is defined by the machine work envelope, which all depends on the material used, and the machine deployed.
5 and 3 Axis Machining |
40” x 22” x 20” (1016mm x 558.8mm x 508mm) |
CNC Router |
Can cut materials that are up to 4’ x 8’ (1219.2mm x 2438.4mm) and 1” (24.5mm) thick |
Other Work Envelope Considerations
Due to tooling reach, the deepest pocket we can machine in an enclosure is 5.75" (146.05mm).
The maximum area of work could be reduced or expanded, depending on the dimensions of required tooling, as well as the specific features required. Contact us at info@protocase.com to discuss your specific project.
