/ Blog / Chamfers and Fillets in CNC Machining
CNC Machining is great for creating complex parts with incredible precision and accuracy, and since it’s automated, it greatly reduces the chances of errors, ensuring high-quality parts are produced quickly.
At Protocase, we have the capability to build fully-finished machined parts. To give you a better idea of our CNC Machining process, we have a Complexity Guide, which you can download here.
For many of you, CNC machining is crucial for producing the detailed parts you require. Even small design details can have a significant impact. Take chamfers and fillets, for example. While they may seem like minor design tweaks, they can impact the geometry and overall performance of your CNC parts.
CNC Machining Process
CNC Machining can create highly precise parts
What Are Chamfers and Fillets?
In CNC machining, a chamfer refers to an angled edge cut along the corners of the material. A fillet is a rounded interior or exterior corner or edge incorporated into a part. Chamfers create a straight edge, while fillets provide a smooth, curved transition.
The Benefits of Chamfers and Fillets
Stress Distribution: Fillets are usually used to reduce stress concentration in materials, which improves the strength and durability of a part. Chamfers can also help with stress and they’re also often used to make parts fit together better.
Aesthetics: Adding chamfers or fillets can improve the visual appeal of your components, making them more attractive.
Safety and Durability: Chamfers help prevent chipping and cracking by eliminating sharp edges. Sharp edges are weak points that can break easily and pose injury risks during handling and assembly. By rounding off these edges, chamfers make parts safer and more comfortable to use.
Two machined parts - one without chamfers and fillets, and another with chamfers and fillets
Top: A machined part without chamfers and fillets
Bottom: A machined part with chamfers (left half) and fillets (right half)
Preparation for Welding: Chamfers are often used to prepare edges for processes like welding. Adding a chamfer can make the welding process smoother and more efficient.
Weight Distribution: Fillets are really important for load-bearing components. They help distribute the load more evenly, which reduces the risk of dealing with cracks and material fatigue.
Improved Fluid Dynamics: Fillets can improve the aerodynamic or hydrodynamic properties of a part by allowing fluids to flow more smoothly.
Considerations for Implementing Chamfers and Fillets
While chamfers and fillets offer numerous advantages, they can also introduce challenges. Adding these features may require additional setups or specialized tooling, potentially extending lead times. This is crucial to consider, especially for urgent projects requiring quick turnaround times.
When submitting a design featuring chamfers or fillets, you might find that our engineering team suggests modifications during the quoting process. We can certainly incorporate these features, and they typically won’t be a problem, but it’s essential to be aware of any design details that might increase cost and lead times.
If they are vital to your design, we will make it happen. By adding these features, you can significantly enhance both the functionality and longevity of your machined parts, resulting in a more precise and consistent final product.
A machined part with fillets and chamfers
Fillets (left half) and chamfers (right half) can improve a machined part’s functionality
Need Help with Your Design?
If you have questions about incorporating chamfers and fillets into your design or need assistance, reach out to your Protocase Account Manager.
For those looking for help designing machined parts, check out our Design Services. Whether you have a rough idea, a sketch, or specific components, our team is ready to assist you.
In summary, chamfers and fillets can elevate the quality and performance of your machined parts. While they may add some complexity to the machining process, the benefits definitely make it worth it!
